On the system that is going to be the install server, log in and become root.
This system must have a CD-ROM drive and be part of the site's network and name service. The system must also be in the NIS or NIS+ name service. (If your site doesn't use the NIS or NIS+ name service, you must distribute information about this system by following your site's policies.)
This procedure assumes that the system is running Volume Management. For detailed information about managing CDs without Volume Management, see the System Administration Guide, Volume I.
Insert the Solaris CD into the CD-ROM drive.
This is the Solaris CD that you want to provide to the systems over the network.
Mount the Solaris CD (if needed).
Volume management automatically mounts the Solaris CD on /cdrom/cdrom0/s0 or /cdrom/cdrom0/s2.
Determine your next step based on whether or not you want to copy the Solaris CD to the install server's hard disk.
If You ... |
Then ... |
Want to copy the Solaris CD |
Go to Step 5. |
Do not want to copy the Solaris CD |
Go to Step 7. |
Change directory to the Tools directory on the mounted Solaris CD.
# cd Solaris_2.7/Tools |
Copy the Solaris CD to the install server's hard disk by using the setup_install_server command.
# ./setup_install_server install_dir_path |
install_dir_path |
Specifies the directory where the Solaris CD will be copied. The directory must be empty. |
The setup_install_server command indicates if you do not have enough disk space for the Solaris CD. Use the df -kl command to determine available disk space.
After copying the Solaris CD, you can use the patchadd -C command to patch the files located on the mini root (i.e. Solaris_2.7/Tools/Boot)on the net install image created by setup_install_server. This enables Solaris installation commands and other mini root commands to be patched.
Determine your next step based on whether or not the install server is on the same subnet as the system to be installed.
If Install Server Is ... |
Then ... |
On same subnet as the system to be installed |
You don't need to create a boot server. Go to "Setting Up Systems to Be Installed Over the Network". |
Follow the steps in "How to Create a Boot Server on a Subnet ". You must complete this procedure when the install server is not on the same subnet as the system to be installed. |
The following example creates an install server by copying the Solaris CD to the install server's /export/install directory.
# cd /cdrom/cdrom0/s0/Solaris_2.7/Tools # ./setup_install_server /export/install |
The install server is now created. If the install server is not on the same subnet as the system to be installed, go to "How to Create a Boot Server on a Subnet ". To set up systems to be installed from the install server, go to "Setting Up Systems to Be Installed Over the Network".
