# profile keywords profile values
[This profile upgrades a system by reallocating disk space. In this example, disk space must be reallocated because some file systems on the system did not have enough room for the upgrade.] install_type upgrade
[The root file system on c0t3d0s2 is upgraded.] root_device c0t3d0s2
[A remote system named timber will be used to back up data during the disk space reallocation.] backup_media remote_filesystem timber:/export/scratch
[The layout_constraint keywords designate that auto-layout can change slice 2 and 5 (the slices can be moved to another location and their size can be changed) and it can move slice 5 (the slice can be moved to another location but its size stays the same) when it tries to reallocate disk space for the upgrade.] layout_constraint c0t3d0s2 changeable 100
layout_constraint c0t3d0s4 changeable
layout_constraint c0t3d0s5 movable
[The binary compatibility package (SUNWbcp) will not be installed on the system after the upgrade.] package SUNWbcp delete
[This code ensures that the OpenLook and X Windows man pages and the universal multiplexor software are selected to be installed if they are not installed on the system. (All packages already on the system are automatically upgraded.)] package SUNWolman add
package SUNWxwman add
cluster SUNWCumux add
[The German localization packages are selected to be installed on the system.] locale de
