cluster cluster_name [add | delete] |
cluster (adding or deleting clusters) can be used with both the initial installation and upgrade options.
cluster designates whether a cluster should be added or deleted from the software group that will be installed on the system. add or delete indicates whether the cluster should be added or deleted. If you do not specify add or delete, add is set by default.
cluster_name must be in the form SUNWCname. To view detailed information about clusters and their names, start Admintool on an installed system and choose Software from the Browse menu.
All clusters already on the system are automatically upgraded.
If you specify cluster_name add, and cluster_name is not installed on the system, the cluster is installed.
If you specify cluster_name delete, and cluster_name is installed on the system, the package is deleted before the upgrade begins.
