cluster group_name |
cluster designates what software group to add to the system. The cluster names for the software groups are:
Software Group | group_name |
Core | SUNWCreq |
End user system support | SUNWCuser |
Developer system support | SUNWCprog |
Entire distribution | SUNWCall |
Entire distribution plus OEM support (SPARC-based systems only) | SUNWCXall |
You can specify only one software group in a profile, and it must be specified before other cluster and package entries. If you do not specify a software group with cluster, the end user software group (SUNWCuser) is installed on the system by default.
