client_swap swap_size |
client_swap defines the amount of swap space (swap_size in Mbytes) to allocate for each diskless client. If you do not specify client_swap, 32 Mbytes of swap space is allocated.
Example:
client_swap 64
The example defines that each diskless client will have a swap space of 64 Mbytes.
client_swap can be used only when system_type is specified as server.
