# profile keywords profile values
install_type initial_install
system_type standalone
[The file system slices are determined by the filesys keywords (explicit value). The size of root is based on the selected software (auto value) and is installed on c0t0d0s0; the size of swap is set to 32 Mbytes and is installed on c0t3d0s1; and usr is based on the selected software and the installation program determines where it is installed (any value).] partitioning explicit
filesys c0t0d0s0 auto /
filesys c0t3d0s1 32 swap
filesys any auto usr
[The entire distribution software group (SUNWCall) is installed on the system. ] cluster SUNWCall
