Solaris Advanced Installation Guide
Mounting Remote File Systems and Adding and Deleting Packages
# profile keywords       profile values
 [This profile keyword is required in every profile.]  install_type            initial_install
 [This profile keyword defines that the system will be installed as a standalone system.]  system_type             standalone
 [The file system slices are determined by the software to be installed (default value); however, the size of swap is set to 60 Mbytes and is installed on any disk (any value). The standard and OpenWindows man pages are mounted from the file server, s_ref, on the network.]  partitioning            default
	filesys                 any 60 swap   # specify size of /swap
	filesys                 s_ref:/usr/share/man - /usr/share/man ro
	filesys                 s_ref:/usr/openwin/share/man -
                              /usr/openwin/share/man ro,quota
 [The developer software group (SUNWCprog) is installed on the system.]  cluster                 SUNWCprog
 [Because the man pages are being mounted remotely, those packages are selected not to be installed on the system; however, the packages containing the OPEN LOOK and X Window System demo programs and images are selected to be installed on the system.]  package                 SUNWman delete
	package                 SUNWolman delete
	package                 SUNWxwman delete
 package                 SUNWoldem add
 package                 SUNWxwdem add
	package                 SUNWoldim add
	package                 SUNWxwdim add
