Some of the options that you can include with the -o flag are:
The pathname file system is shared read-write or read-only to all clients.
The file system is shared read-write to the listed clients only. All other requests are denied. Starting with the Solaris 2.6 release, the list of clients defined in accesslist has been expanded. See "Setting Access Lists With the share Command" for more information. You can use this option to override an -ro option.
The options that you can use with NFS file systems only include:
This option enables an NFS server supporting the NFS version 2 protocol to be configured to do access control for NFS version 2 clients. Without this option all clients are given minimal access. With this option the clients have maximal access. For instance, on file systems shared with the -aclok option, if anyone has read permissions, then everyone does. However, without this option, it is possible to deny access to a client who should have access permissions. Whether it is preferred to permit too much access or to permit too little, depends on the security systems already in place. See "Securing Files (Tasks)" in System Administration Guide, Volume II for more information about access control lists (ACLs).
To take advantage of ACLs, it is best to have clients and servers run software that supports the NFS version 3 and NFS_ACL protocols. If the software only supports the NFS version 3 protocol, then clients get correct access, but cannot manipulate the ACLs. If the software supports the NFS_ACL protocol, then the clients get correct access and can manipulate the ACLs. Starting with release 2.5, the Solaris system supports both protocols.
You use uid to select the user ID of unauthenticated users. If you set uid to -1, the server denies access to unauthenticated users. You can grant root access by setting anon=0, but this will allow unauthenticated users to have root access, so use the root option instead.
You can use the -index=filename option to force the loading of a HyperText Markup Language (HTML) file instead of displaying a listing of the directory when a user accesses an NFS URL. This option mimics the action of current browsers if an index.html file is found in the directory that the HTTP URL is accessing. This is the equivalent of setting the DirectoryIndex option for httpd. For instance, if the dfstab file entry looks like:
share -F nfs -o ro,public,index=index.html /export/web |
these URLs will display the same information:
nfs://<server>/<dir> nfs://<server>/<dir>/index.html nfs://<server>//export/web/<dir> nfs://<server>//export/web/<dir>/index.html http://<server>/<dir> http://<server>/<dir>/index.html |
This option signals that all attempts to enable the setuid or setgid mode should be ignored. NFS clients cannot be able to create files with the setuid or setgid bits on.
The -public option has been added to the share command to enable WebNFS browsing. Only one file system on a server can be shared with this option.
The server gives root access to the hosts in the list. By default, the server does not give root access to any remote hosts. If the selected security mode is anything other than -sec=sys, then you can only include client host names in the accesslist. Starting with the Solaris 2.6 release, the list of clients defined in accesslist is expanded. See "Setting Access Lists With the share Command" for more information.
Granting root access to other hosts has far-reaching security implications; use the -root= option with extreme caution.
mode selects the security modes that are needed to get access to the file system. By default, the security mode is UNIX authentication. You can specify multiple modes, but use each security mode only once per command line. Each -mode option applies to any subsequent -rw, -ro, -rw=, -ro=, -root=, and -window= options, until another -mode is encountered. Using -sec=none maps all users to user nobody.
value selects the maximum life time in seconds of a credential on the NFS server. The default value is 30000 seconds or 8.3 hours.
