In Solaris releases prior to 2.6, the accesslist included with either the -ro=, -rw=, or -root= option of the share command were restricted to a list of host names or netgroup names. Starting with the Solaris 2.6 release, the access list can also include a domain name, a subnet number, or an entry to deny access. These extensions should make it easier to control file access control on a single server, without having to change the name space or maintain long lists of clients.
This command provides read-only access for most systems but allows read-write access for rose and lilac:
# share -F nfs -o ro,rw=rose:lilac /usr/src |
In the next example, read-only access is assigned to any host in the eng netgroup. The client rose is specifically given read-write access.
# share -F nfs -o ro=eng,rw=rose /usr/src |
You cannot specify both rw and ro without arguments. If no read-write option is specified, the default is read-write for all clients.
To share one file system with multiple clients, you must enter all options on the same line, because multiple invocations of the share command on the same object "remember" only the last command run. This command enables read-write access to three client systems, but only rose and tulip are given access to the file system as root.
# share -F nfs -o rw=rose:lilac:tulip,root=rose:tulip /usr/src |
When sharing a file system using multiple authentication mechanisms, make sure to include the -ro, -ro=, -rw, -rw=, -root, and -window options after the correct security modes. In this example, UNIX authentication is selected for all hosts in the netgroup named eng. These hosts can only mount the file system in read-only mode. The hosts tulip and lilac will be able to mount the file system read-write if they use Diffie-Hellman authentication. With these options, tulip and lilac will be able to mount the file system read-only even if they are not using DH authentication, if the host names are listed in the eng netgroup.
# share -F nfs -o sec=dh,rw=tulip:lilac,sec=sys,ro=eng /usr/src |
Even though UNIX authentication is the default security mode, it is not included if the -sec option is used, so it is important to include a -sec=sys option if UNIX authentication is to be used with any other authentication mechanism.
You can use a DNS domain name in the access list by preceding the actual domain name with a dot. The dot indicates that the string following it is a domain name, not a fully qualified host name. The following entry allows mount access to all hosts in the eng.sun.com domain:
# share -F nfs -o ro=.:.eng.sun.com /export/share/man |
In this example, the single "." matches all hosts that are matched through the NIS or NIS+ name spaces. The results returned from these name services do not include the domain name. The ".eng.sun.com" entry matches all hosts that use DNS for name space resolution. DNS always returns a fully qualified host name, so the longer entry is required if you use a combination of DNS and the other name spaces.
You can use a subnet number in an access list by preceding the actual network number or the network name with "@". This differentiates the network name from a netgroup or a fully qualified host name. You must identify the subnet in either /etc/networks or in a NIS or NIS+ name space. The following entries have the same effect if the 129.144 subnet has been identified as the eng network:
# share -F nfs -o ro=@eng /export/share/man # share -F nfs -o ro=@129.144 /export/share/man # share -F nfs -o ro=@129.144.0.0 /export/share/man |
The last two entries show that it is not necessary to include the full network address.
If the network prefix is not byte aligned, as with Classless Inter-Domain Routing (CIDR), the mask length can be explicitly specified on the command line. The mask length is defined by following either the network name or the network number with a slash and the number of significant bits in the prefix of the address. For example:
# share -f nfs -o ro=@eng/17 /export/share/man # share -F nfs -o ro=@129.144.132/17 /export/share/man |
In these examples, the "/17" indicates that the first 17 bits in the address are to be used as the mask. For additional information on CIDR, look up RFC 1519.
You can also select negative access by placing a "-" before the entry. Notice that because the entries are read from left to right, you must place the negative access entries before the entry they apply to:
# share -F nfs -o ro=-rose:.eng.sun.com /export/share/man |
This example would allow access to any hosts in the eng.sun.com domain except the host named rose.
