The following example extracts the files /etc/passwd and /etc/shadow from the backup tape.
# cd /var/tmp # ufsrestore if /dev/rmt/0 ufsrestore> ls .: .cpr_config etc/ lost+found/ sbin/ usr/ TT_DB/ export/ mnt/ sccs/ var/ b/ home/ net/ share/ vol/ bin kernel/ opt/ shared/ ws/ dev/ lib platform/ src/ xfn/ devices/ license/ proc/ tmp/ ufsrestore> cd etc ufsrestore> add passwd shadow ufsrestore> verbose verbose mode on ufsrestore> extract Extract requested files You have not read any volumes yet. Unless you know which volume your file(s) are on you should start with the last volume and work towards the first. Specify next volume #: 1 extract file ./etc/shadow extract file ./etc/passwd Add links Set directory mode, owner, and times. set owner/mode for `.'? [yn] n ufsrestore> quit # |
