The following example restores the passwd and shadow files to the /var/tmp directory.
# cd /var/tmp # ufsrestore xvf /dev/rmt/0 ./etc/passwd ./etc/shadow Verify volume and initialize maps Media block size is 126 Dump date: Tue Jun 09 14:30:16 1998 Dumped from: the epoch Level 0 dump of / on pluto:/dev/dsk/c0t3d0s0 Label: none Extract directories from tape Initialize symbol table. Warning: ./etc: File exists Extract requested files You have not read any volumes yet. Unless you know which volume your file(s) are on you should start with the last volume and work towards the first. Specify next volume #: 1 extract file ./etc/passwd Add links Set directory mode, owner, and times. set owner/mode for `.'? [yn] n Directories already exist, set modes anyway? [yn] n # cd etc # mv passwd /etc # mv shadow /etc # ls -l etc |
