The following prerequisites must be met to use a remote tape drive:
The local hostname (and optionally the username of the user doing the copy) must appear in the remote system's /etc/hosts.equiv file, or the user doing the copy must have his or her home directory accessible on the remote machine, and have the local machine name in $HOME/.rhosts. See hosts.equiv(4) for more information.
An entry for the remote system must be in the local system's /etc/inet/hosts file or in the name service hosts file.
To test whether or not you have the appropriate permission to execute a remote command, try the following.
$ rsh remotehost echo test |
If "test" is echoed back to you, you have permission to execute remote commands. If "Permission denied" is echoed, check your setup as described in step 1 above.
To copy files to a remote tape drive use the tar and dd commands.
$ tar cf - files | rsh remotehost dd of=/dev/rmt/n obs=blocksize |
tar cf |
Creates a tape archive and specifies the tape device. |
- (Hyphen) |
Represents a placeholder for the tape device. |
files |
Identifies files to be copied. |
| rsh remotehost |
Pipe the tar command's output to a remote shell to copy the files. |
dd of=/dev/rmt/n |
Represents the output device. |
obs=blocksize |
Represents the blocking factor. |
Remove the tape from the drive and write the names of the files on the tape label.
# tar cvf - * | rsh mercury dd of=/dev/rmt/0 obs=126b a answers/ 0 tape blocks a answers/test129 1 tape blocks a sc.directives/ 0 tape blocks a sc.directives/sc.190089 1 tape blocks a tests/ 0 tape blocks a tests/test131 1 tape blocks 6+9 records in 0+1 records out |
