Change to a temporary directory.
$ cd /var/tmp |
To extract files to a remote tape drive use the tar and dd commands.
$ rsh remotehost dd if=/dev/rmt/n | tar xvBpf - |
rsh remotehost |
Is a remote shell that is started to extract the files from the tape device using the dd command. |
dd if=/dev/rmt/n |
Indicates the input device. |
| tar xvBpf - |
Pipes the output of the dd command to the tar command used to restored the files. |
Verify that the files have been extracted.
$ ls -l /var/tmp |
$ rsh mercury dd if=/dev/rmt/0 | tar xvBpf - x answers/, 0 bytes, 0 tape blocks x answers/test129, 48 bytes, 1 tape blocks 20+0 records in 20+0 records out x sc.directives/, 0 bytes, 0 tape blocks x sc.directives/sc.190089, 77 bytes, 1 tape blocks x tests/, 0 bytes, 0 tape blocks x tests/test131, 84 bytes, 1 tape blocks $ ls -l /var/tmp |
