The following example shows a full backup of the root (/) file system to a QIC-150 tape (/dev/rmt/0).
# shutdown -g30 -y
# ufsdump 0ucf /dev/rmt/0 /
DUMP: Writing 63 Kilobyte records
DUMP: Date of this level 0 dump: Tue Jun 09 10:14:54 1998
DUMP: Date of last level 0 dump: the epoch
DUMP: Dumping /dev/rdsk/c0t3d0s0 (pluto:/) to /dev/rmt/0.
DUMP: Mapping (Pass I) [regular files]
DUMP: Mapping (Pass II) [directories]
DUMP: Estimated 73708 blocks (35.99MB).
DUMP: Dumping (Pass III) [directories]
DUMP: Dumping (Pass IV) [regular files]
DUMP: Tape rewinding
DUMP: 73582 blocks (35.93MB) on 1 volume at 100 KB/sec
DUMP: DUMP IS DONE
DUMP: Level 0 dump on Tue Jun 09 10:14:54 1998
# ufsrestore tf /dev/rmt/0
2 .
3 ./lost+found
5696 ./usr
11392 ./export
17088 ./export/home
22784 ./export/root
28480 ./export/swap
34176 ./opt
39872 ./var
45568 ./var/sadm
51264 ./var/sadm/install
56960 ./var/sadm/install/admin
57011 ./var/sadm/install/admin/default
(Press Control-d to bring system to run level 3)
