The following example shows a full backup of a local root (/) file system on a Sun 4.1.3 system (mars) to a remote tape device on a Solaris 7 system called pluto.
Notice that when you back up data on a system running SunOS 4.1.3 or a compatible version, you must use the dump command--not the ufsdump command.
# dump 0ucf pluto:/dev/rmt/0 /
DUMP: Date of this level 0 dump: Tue Oct 21 16:05:19 1997
DUMP: Date of last level 0 dump: the epoch
DUMP: Dumping /dev/rsd2a (/) to /dev/rmt/0 on host pluto
DUMP: mapping (Pass I) [regular files]
DUMP: mapping (Pass II) [directories]
DUMP: estimated 8686 blocks (4.24MB) on 0.10 tape(s).
DUMP: dumping (Pass III) [directories]
DUMP: dumping (Pass IV) [regular files]
DUMP: level 0 dump on Tue Oct 21 16:05:19 1997
DUMP: Tape rewinding
DUMP: 8690 blocks (4.24MB) on 1 volume
DUMP: DUMP IS DONE
# restore tf pluto:/dev/rmt/0
2 .
3 ./lost+found
3776 ./export
7552 ./home
11328 ./usr
15104 ./pcfs
3777 ./tftpboot
3778 ./tftpboot/tftpboot
3794 ./tftpboot/boot.sun4c.sunos.4.1.3
7553 ./etc
7554 ./etc/sendmail.cf
7555 ./etc/aliases
7556 ./etc/aliases.dir
7557 ./etc/aliases.pag
7558 ./etc/holidays
7559 ./etc/dumpdates
