Start Solstice Host Manager from the Solstice Launcher and select the name service, if not done already.
See "How to Start Solstice Host Manager" for more information.
Choose Set Defaults from the Edit menu.
The Set Defaults window is displayed.
Fill in the Set Defaults window.
The defaults you select will be the initial defaults values in the Add window. If you need information to complete a field, click on the Help button to see field definitions for this window.
Click on OK.
