The high-level steps in this procedure are:
Adding information about the system
(Optional) Setting up remote install capabilities for the system
(Optional) Installing the system
Start Solstice Host Manager from the Solstice Launcher and select the name service, if not done already.
See "How to Start Solstice Host Manager" for more information.
Select Add from the Edit menu on the Solstice Host Manager Window.
The Add window is displayed.
Fill in the system information, selecting Solaris Standalone or OS Server as the system type.
The system information includes all the fields from the host name through the timezone. If you need information to complete a field, click on the Help button to see field definitions for this window.
If you want to set up remote install capabilities for the system, continue to Step 5. If not, skip to Step 10.
Click on Enable Remote Install.
Select an Install Server.
The Install Server defaults to the current host. Select Other from the Install Server menu to specify another host as the install server.
Click on Set Path to identify the path to the Solaris CD image on the install server.
If the install server is a remote system, note that it must be minimally set up as a managed system.
If You Are Using ... |
And ... |
Then Enter the Path ... |
The Solaris CD as the Solaris CD image |
The Solaris CD is managed by Volume Management |
/cdrom/cdrom0 or /cdrom/cdrom0/s0 or /cdrom/cdrom0/s2 |
The Solaris CD is not managed by Volume Management |
Where you mounted the Solaris CD |
A copy of the Solaris CD on the install server's hard disk (by using setup_install_server) |
To the Solaris CD image |
Select the system's architecture type and OS release from the OS Release menu.
The architecture type must match the system's architecture and the OS release should match the Solaris release you want to remotely install on the system.
If necessary, specify a boot server or profile server.
To specify another server other than the default, select Other from the menu. Select a Profile Server from the Profile Server pull-down menu. You must also specify a path to the boot software on the boot server or the custom JumpStart directory on the profile server.
To set up the other components of a custom JumpStart installation and preconfiguring network and system information, see Solaris Advanced Installation Guide.
Click on OK on the Add window.
Select Save Changes from the File menu to add support for the standalone system or OS server.
The standalone system or OS server is displayed in the Host Manager main window.
Verify the OS server information is correct in the Host Manager main window.
(Optional) Boot and install the standalone system or OS server.
For more information about booting and installing, see Solaris Advanced Installation Guide.
If you are installing an OS server, you must allocate space in /export and /export/swap for the desired number of clients.
The following example shows a completed Add window for the standalone system venus.
If you want to add OS services after you install an OS server, see "How to Add Solaris 7 OS Services to an OS Server".
