Format a disk
Any existing data will be destroyed when a disk is reformatted.
The need for formatting a disk drive has dropped as more and more manufacturers ship their disk drives formatted and partitioned. You may not need to use the format utility when adding a disk drive to an existing system.
If a disk has been relocated and is displaying a lot of disk errors, you can attempt to reformat it, which will automatically remap any bad sectors.
"How to Format a Disk"
Replace a system disk
Chapter 23, SPARC: Adding a Disk (Tasks) or Chapter 24, x86: Adding a Disk (Tasks) or if the system must be reinstalled, Solaris Advanced Installation Guide
Divide a disk into slices
Any existing data will be destroyed when a disk with existing slices is repartitioned and relabeled.
Existing data must be copied to backup media before the disk is repartitioned and restored after the disk is relabeled.
Add a secondary disk to an existing system
Repair a disk drive
Some customer sites prefer to replace rather than repair defective drives. If your site has a repair contract with the disk drive manufacturer, you may not need to use the format utility to repair disk drives.
Repairing a disk drive usually means that a bad sector is added to a defect list. New controllers remap bad sectors automatically with no system interruption.
If the system has an older controller, you may need to remap a bad sector and restore any lost data.
Chapter 25, The format Utility (Reference)
