System Administration Guide, Volume I
Determining Which Slices to Use
When you set up a disk's file systems, you choose not only the size of each slice, but also which slices to use. Your decisions about these matters depend on the configuration of the system to which the disk is attached and the software you want to install on the disk.
There are five system configurations:
Each system configuration requires the use of different slices. Table 21-4 lists these requirements.
Table 21-4 System Configurations and Slice Requirements
Slice
Servers
Diskless Clients
Standalone
Systems
AutoClient
Systems
0
root
(on server)
root
root
1
swap
(on server)
swap
swap
2
3
/export
4
/export/swap
5
/opt
(on server)
/opt
(on server)
6
/usr
(on server)
/usr
(on server)
7
/export/home
(on server)
/home
(on server)
See Chapter 4, Managing Server and Client Support (Tasks) for more information about system configurations.
Note -
The Solaris installation program provides slice size recommendations based on the software you select for installation.
