read
Read each sector on this disk. Repairs defective blocks as a default.
refresh
Read then write data on the disk without harming the data. Repairs defective blocks as a default.
test
Write a set of patterns to the disk without harming the data. Repairs defective blocks as a default.
write
Write a set of patterns to the disk then read the data on the disk back. Destroys existing data on the disk. Repairs defective blocks as a default.
compare
Write a set of patterns to the disk, read the data back, and compare it to the data in the write buffer. Destroys existing data on the disk. Repairs defective blocks as a default.
purge
Remove all data from the disk so that the data can't be retrieved by any means. Data is removed by writing three distinct patterns over the entire disk (or section of the disk), then writing an hex-bit pattern if the verification passes.
verify
Write unique data to each block on the entire disk in the first pass. Read and verify the data in the next pass. Destroys existing data on the disk. Repairs defective blocks as a default.
print
View the data in the read/write buffer.
setup
Specify the following analysis parameters
Analyze entire disk? yes
Starting block number: depends on drive
Ending block number: depends on drive
Loop continuously? no
Number of passes: 2
Repair defective blocks? yes
Stop after first error? no
Use random bit patterns? no
Number of blocks per transfer: 126 (0/n/nn)
Verify media after formatting? yes
Enable extended messages? no
Restore defect list? yes
Restore disk label? yes
Defaults are shown in bold.
config
View the current analysis parameters.
quit
Exit the analyze menu.
