The defect menu looks like this.
format> defect DEFECT MENU: primary - extract manufacturer's defect list grown - extract manufacturer's and repaired defects lists both - extract both primary and grown defects lists print - display working list dump - dump working list to file quit defect> |
Table 25-5 describes the defect menu items.
Table 25-5 The defect Menu Item Descriptions
The Command ... |
Allows You To ... |
primary |
Read the manufacturer's defect list from the disk drive and update the in-memory defect list. |
grown |
Read the grown defect list (defects that have been detected during analysis) and update the in-memory defect list. |
both |
Read both the manufacturer's and grown defect list and update the in-memory defect list. |
View the in-memory defect list. |
dump |
Save the in-memory defect list to a file. |
quit |
Exit the defect menu. |
