Become superuser.
Enter the format utility.
# format |
Enter the number of the disk that you want to label from the list displayed on your screen.
Specify disk (enter its number):1 |
Use the table below to determine how to label the disk.
If the Disk Is Unlabeled and Was Successfully Configured ... |
If the Disk Was Labeled and You Want to Change the Type, or Format Was Not Able to Automatically Configure the Disk ... |
Format will ask if you want to label the disk. Go to step 5 to label the disk. |
You must specify the disk type. Go to steps 6-7 to set the disk type and label the disk. |
Label the disk by typing y at the Label it now? prompt.
Disk not labeled. Label it now? y |
The disk is now labeled. Go to step 10 to exit the format utility.
Enter type at the format> prompt.
format> type |
Format displays the Available Drive Types menu.
Select a disk type from the list of possible disk types.
Specify disk type (enter its number)[8]: 8 |
Label the disk. If the disk is not labeled, the following message is displayed.
Otherwise you are prompted with this message:
Ready to label disk, continue? y |
Use the verify command from the format main menu to verify the disk label.
format> verify |
Exit the format utility by typing q at the format> prompt.
partition> q format> q # |
The following example automatically configures and labels a 424-Mbyte disk.
# format c1t0d0: configured with capacity of 404.65MB AVAILABLE DISK SELECTIONS: 0. c0t3d0 <SUN0424 cyl 1151 alt 2 hd 9 sec 80> /sbus@1,f8000000/esp@0,800000/sd@3,0 1. c1t0d0 <SUN0424 cyl 1151 alt 2 hd 9 sec 80> /sbus@1,f8000000/QLGC,isp@1,10000/sd@0,0 Specify disk (enter its number): 1 Disk not labeled. Label it now? yes format> verify # |
