Examine disk label information by using the prtvtoc(1M) command. See Chapter 21, Disk Management (Overview) for a detailed description of the disk label and the information displayed by the prtvtoc command.
Become superuser.
Display the disk label information by using the prtvtoc command.
# prtvtoc /dev/rdsk/device-name |
device-name |
Raw disk device you want to examine. |
The following example shows the disk label information for disk /dev/rdsk/c0t0d0s0.
# prtvtoc /dev/rdsk/c0t0d0s0
* c0t0d0s0 partition map
* Dimensions:
* 512 bytes/sector
* 36 sectors/track
* 9 tracks/cylinder
* 324 sectors/cylinder
* 1272 cylinders
* 1254 accessible cylinders
* Flags:
* 1: unmountable
* 10: read-only
* First Sector Last
* Partition Tag Flags Sector Count Sector Mount Directory
0 2 00 0 37260 37259 /
1 3 01 37260 77760 115019
2 5 00 0 406296 406295
6 4 00 115020 283824 398843 /usr
7 6 00 398844 7452 406295 /export/home
