The following example displays slice information for disk /dev/rdsk/c0t3d0.
# format Searching for disks...done Specify disk (enter its number):1 Selecting c0t3d0 format> partition partition> print Current partition table (original): Total disk cylinders available: 1866 + 2 (reserved cylinders) Part Tag Flag Cylinders Size Blocks 0 root wm 0 - 292 80.12MB (293/0/0) 164080 1 swap wu 293 - 410 32.27MB (118/0/0) 66080 2 backup wm 0 - 1865 510.23MB (1866/0/0) 1044960 3 unassigned wm 0 0 (0/0/0) 0 4 unassigned wm 0 0 (0/0/0) 0 5 home wm 411 - 1311 246.37MB (901/0/0) 504560 6 usr wm 1312 - 1718 111.29MB (407/0/0) 227920 7 unassigned wm 1719 - 1865 40.20MB (147/0/0) 82320 partition> q format> q # |
See Chapter 21, Disk Management (Overview) for a detailed description of the slice information displayed in these examples.
The following example displays the slice information on disk /dev/rdsk/c0t0d0.
# format Searching for disks...done Specify disk (enter its number): 0 selecting c0t0d0 [disk formatted] format> partition partition> print Current partition table (original): Total disk cylinders available: 1479 + 2 (reserved cylinders) Part Tag Flag Cylinders Size Blocks 0 root wm 1 - 400 108.01MB (400/0/0) 221200 1 swap wu 401 - 556 42.12MB (156/0/0) 86268 2 backup wu 0 - 1479 399.63MB (1480/0/0) 818440 3 unassigned wm 0 0 (0/0/0) 0 4 unassigned wm 0 0 (0/0/0) 0 5 unassigned wm 557 - 734 48.06MB (178/0/0) 98434 6 usr wm 735 - 1401 180.10MB (667/0/0) 368851 7 home wm 1402 - 1476 20.25MB (75/0/0) 41475 8 boot wu 0 - 0 0.27MB (1/0/0) 553 9 unassigned wm 0 0 (0/0/0) 0 partition> q format> q |
