Use the -h option of the cachefslog(1M) command to stop the logging process.
$ cachefslog -h mount-point |
The following example halts logging on /home/stuff.
$ cachefslog -h /home/stuff not logged: /home/stuff |
If you get a system response other than the one specified in the above example, you did not successfully stop the logging process. Check to see if you are using the correct log file name and mount point.
