You can also use the cachefslog(1M) command with no options to locate a log file for a particular mount point.
$ cachefslog mount-point |
mount-point |
Specifies the cached file system for which you want to view the statistics. |
The following example shows what you would see if a log file has been set up. The location of the log file is /var/tmp/stufflog.
$ cachefslog /home/stuff /var/tmp/stufflog: /home/stuff |
The following example shows that no log file has been set up for the specified file system.
$ cachefslog /home/zap not logged: /home/zap |
