Type the stop key sequence for your system. The specific stop key sequence depends on your keyboard type. For example, you can press Stop-A or L1-A. On terminals, press the Break key.
The monitor displays the ok PROM prompt.
Use the sync command at the ok prompt to synchronize the disk and write the crash dump.
> n ok sync |
When you see the syncing file systems... message, press the abort key sequence for your system again.
Boot the system using the kernel debugger.
ok boot kadb |
Identify kadb booting messages to verify the system is booted using the kernel debugger.
Rebooting with command: kadb Boot device: /iommu/sbus/espdma@4,800000/esp@4,8800000/sd@3,0 . . . |
Press <Stop-a> ok sync syncing file systems... Press <Stop-a> ok boot kadb |
