Type the stop key sequence for your system. The specific stop key sequence depends on your keyboard type. For example, you can press Stop-a or L1-a. On terminals, press the Break key.
The monitor displays the ok PROM prompt.
Use the sync command at the ok prompt to synchronize the disk and write the crash dump.
> n ok sync |
After the crash dump is written to disk, the system will continue to reboot.
Verify the system boots to run level 3.
The login prompt is displayed when the boot process has finished successfully.
hostname console login: |
Press <Stop-a> ok sync |
