You can play musical CDs from a CD-ROM attached to your Solaris system. You'll need to access Workman, which is public domain software, and you must attach external speakers or headphones independently to the CD-ROM drive; speakers attached to the system hardware will not work.
Once you configure your system, you can play a musical CD simply by inserting it into the CD-ROM drive. The Workman control panel is automatically displayed on your desktop.
Become superuser.
Edit /etc/rmmount.conf.
Add the following line under # Actions, before the cdrom action, as shown in the example below.
# Actions action cdrom action_workman.so path/workman workman-options |
path |
The directory in which you have placed the Workman software. |
workman-options |
The options allowed by the Workman software |
This example shows an /etc/rmmount.conf file modified to support the Workman software.
# @(#)rmmount.conf 1.3 96/05/10 SMI # # Removable Media Mounter configuration file. # # File system identification ident hsfs ident_hsfs.so cdrom ident ufs ident_ufs.so cdrom floppy rmscsi pcmem ident pcfs ident_pcfs.so floppy rmscsi pcmem # Actions action cdrom action_workman.so /usr/dist/exe/workman action cdrom action_filemgr.so action floppy action_filemgr.so action rmscsi action_filemgr.so # File System Sharing share cdrom* share floppy* |
