You can configure your system to share its CD-ROM drives; in other words, make any CDs in those drives available to other systems. (This does not apply to musical CDs.) Once your CD-ROM drives are shared, other systems can access the CDs they contain simply by mounting them, as described in "How to Access CDs on Other Systems".
Become superuser.
Find out whether the NFS daemon (nfsd) is running.
# ps -ef | grep nfsd root 14533 1 17 10:46:55 ? 0:00 /usr/lib/nfs/nfsd -a 16 root 14656 289 7 14:06:02 pts/3 0:00 grep nfsd |
If the daemon is running, a line for /usr/lib/nfs/nfsd will appear, as shown above. If the daemon is not running, only the grep nfsd line will appear.
Select an option from the following table.
If ... |
Then ... |
nfsd is running |
Go to Step 8 |
nfsd is not running |
Continue with Step 4 |
Create a dummy directory for nfsd to share.
# mkdir /dummy-dir |
dummy-dir |
Can be any directory name; for example, dummy. This directory will not contain any files. Its only purpose is to "wake up" the NFS daemon so that it notices your shared CD-ROM. |
Add the following entry into /etc/dfs/dfstab.
share -F nfs -o ro [-d comment] /dummy-dir |
When you start the NFS daemon, it will see this entry, "wake up," and notice the shared CD-ROM drive. Note that the comment (preceded by -d) is optional.
# /etc/init.d/nfs.server start |
Verify that the NFS daemon is indeed running.
# ps -ef | grep nfsd root 14533 1 17 10:46:55 ? 0:00 /usr/lib/nfs/nfsd -a 16 root 14656 289 7 14:06:02 pts/3 0:00 /grep nfsd |
Eject any CD currently in the drive.
# eject cdrom0 |
Assign root write permissions to /etc/rmmount.conf.
# chmod 644 /etc/rmmount.conf |
Add the following lines to /etc/rmmount.conf.
# File System Sharing share cdrom* |
These lines share any CD loaded into your system's CD-ROM drive. You can, however, limit sharing to a particular CD or series of CDs, as described in share(1M).
Remove write permissions from /etc/rmmount.conf.
# chmod 444 /etc/rmmount.conf |
This step returns the file to its default permissions.
Load a CD.
The CD you now load, and all subsequent CDs, will be available to other systems. Remember to wait until the light on the drive stops blinking before you verify this task.
To access the CD, the remote user must mount it by name, according to the instructions in "How to Access CDs on Other Systems".
Verify that the CD is indeed available to other systems by using the share command.
If the CD is available, its share configuration will be displayed. (The shared dummy directory will also be displayed.)
# share - /dummy ro "dummy dir to wake up NFS daemon" - /Solaris_2.7_sparc ro "" |
The following example makes any CD loaded into the local system's CD-ROM drive available to other systems on the network.
root 10127 9986 0 08:25:01 pts/2 0:00 grep nfsd
root 10118 1 0 08:24:39 ? 0:00 /usr/lib/nfs/nfsd -a
# mkdir /dummy
# vi /etc/dfs/dfstab
(Add the following line:)
share -F nfs -o ro /dummy
# eject cdrom0
# vi /etc/rmmount
(Add the following line to the File System Sharing section.)
share cdrom*
(Load a CD.)
# share
- /dummy ro ""
- /cdrom/solaris_2_6_sparc/s5 ro ""
- /cdrom/solaris_2_6_sparc/s4 ro ""
- /cdrom/solaris_2_6_sparc/s3 ro ""
- /cdrom/solaris_2_6_sparc/s2 ro ""
- /cdrom/solaris_2_6_sparc/s1 ro ""
- /cdrom/solaris_2_6_sparc/s0 ro ""
