In general, when installing Sun packages on clients in a homogeneous environment, follow the guidelines in Table 17-2.
Table 17-2 Installing Sun Packages on Clients in a Homogeneous Environment
If the Package's Files Are Installed in The ... |
Then ... |
root (/) file system |
Add the package using the procedure in "How to Add a Package to a Diskless or AutoClient System's root (/) File System". |
/usr |
Add the package using the procedure in "How to Add Packages to a Standalone System". |
You can determine where a Sun package's files are installed by using the procedure "How to Determine Where a Package's Files Will Be Installed".
