Remove a software package from a diskless client's OS server with the pkgrm -R command.
server# pkgrm -R rootpath pkgid ... |
-R rootpath |
Specifies the mount point of the client's root file system. |
pkgid |
(Optional) Is the name of one or more packages (separated by spaces) to be removed. If omitted, pkgrm removes all available packages. |
Files in the client's package database that are marked shared are not removed from the server, but are removed from the client's database. If all clients have removed the package, you can remove the shared files from the server by using a separate invocation of pkgrm on the server.
Verify that the package has been removed successfully by using the pkginfo command.
server# pkginfo -R rootpath | egrep pkgid |
If pkgid is installed, the pkginfo command returns a line of information about it. Otherwise, pkginfo returns the system prompt.
In the following example, assume the client's root file system is shared. Also, assume these commands are executed on the client's server.
server# pkgrm -R /export/root/client-1 SUNWaudio The following package is currently installed. SUNWaudio Do you want to remove this package? y/n/q? y . . . |
