The name of this release is Solaris 7 but code and path or package path names may use Solaris 2.7 or SunOS 5.7. Always follow the code or path as it is written.
The following example shows a command to install the SUNWadmr (software to support system and network administration) package from a server onto a diskless client's root file system. In this case, the diskless client's root file system is /export/root/client-1. This example assumes the SUNWadmr package is available from a mounted SPARC 2.7 Solaris CD (/cdrom/cdrom0/s0/Solaris_2.7/Product). The example also shows use of pkginfo and pkgchk to verify that the package's files were installed properly.
server# pkgadd -R /export/root/client-1 -d /cdrom/cdrom0/s0/Solaris_2.7/Product SUNWadmr . . . Installation of <SUNWadmr> complete. server# pkginfo -R /export/root/client-1 | egrep SUNWadmr system SUNWadmr System & Network Administration Root server# pkgchk -v -R /export/root/client-1 SUNWadmr /etc /etc/init.d /etc/init.d/autoinstall /etc/init.d/sysid.net /etc/init.d/sysid.sys /etc/rc2.d /etc/rc2.d/S30sysid.net /etc/rc2.d/S71sysid.sys /etc/rc2.d/S72autoinstall /sbin /sbin/bpgetfile |
