Log in to a system as superuser.
Check the status of an installed package with the pkgchk command.
# pkgchk -a | -c -v pkgid ... # pkgchk -d spooldir pkgid ... |
-a |
Specifies to audit only the file attributes (that is, the permissions), rather than the file attributes and contents, which is the default for pkgchk. |
-c |
Specifies to audit only the file contents, rather than the file contents and attributes, which is the default for pkgchk. |
-v |
Specifies verbose mode, which displays file names as pkgchk processes them. |
-d spooldir |
Specifies the absolute path of the spool directory. |
pkgid |
(Optional) Is the name of one or more packages (separated by spaces). If you do not specify a pkgid, pkgchk checks all the software packages installed on the system. If omitted, pkgchk displays all available packages. |
The following example shows how to check the contents of a package.
# pkgchk -c SUNWadmfw |
If pkgchk determines there are no errors, it returns the system prompt. Otherwise, it reports the error.
The following example shows how to check the file attributes of a package.
# pkgchk -a SUNWadmfw |
The following example shows how to check a software package copied to a spool directory (/export/install/packages).
# pkgchk -d /export/install/packages ## checking spooled package <SUNWadmap> ## checking spooled package <SUNWadmfw> ## checking spooled package <SUNWadmc> ## checking spooled package <SUNWsadml> |
The checks made on a spooled package are limited because not all information can be audited until a package is installed.
