If install4x is to use a CD-ROM drive on a remote system running the Solaris 7 operating environment, after you install the CD into the drive, Volume Management automatically mounts the CD directory on /cdrom/volume1/s0. Then type the following command.
# share -F nfs -o ro /cdrom/volume1/s0 |
If you are not sharing other NFS systems at boot time, you need to invoke the mountd(1M) and nfsd(1M) daemons.
Type the following commands on the local system.
# mkdir /cdrom
# mount -F nfs -o ro cd-host:/cdrom/volume1/s0 /cdrom |
