If install4x is to use a CD-ROM drive on a remote system that is running the SunOS release 4.x software, type the following as superuser on the remote system.
# mkdir /cdrom
# mount -t hsfs -r /dev/sr0 /cdrom |
Once you have typed the previous commands, edit the /etc/exports and insert the following line.
/cdrom -ro |
Then type the following command on the remote system.
# exportfs /cdrom |
Type the following commands on the local system.
# mkdir /cdrom
# mount -F nfs -o ro cd-host:/cdrom /cdrom |
