The Workspace Properties window has three buttons:
Reset to Standard displays (but does not implement) the system default settings--that is, the settings determined by your system administrator. Change bars mark your previously-applied nonstandard settings.
Reset ignores any changes and immediately reverts to previously-applied settings.
Apply implements changes. Most changes take place immediately, while others do not take place until you open a new application or restart the OpenWindows software.
To change settings in more than one category, be sure to select Apply before continuing to the next category. Unlike previous versions, this version of OpenWindows software treats changes to each category separately.
