The Sort By Options allow you to choose how the files in the file pane are sorted. You can choose any of the following settings:
Name, to sort the files alphabetically
Type, to sort the files in alphabetical groups by file type, with folders first, followed by files, then by applications
Size, to sort the files by size, largest to smallest
Date, to sort the files in reverse chronological order (newest to oldest)
