The following explains what to do with your floppy disk once you have inserted it into your drive. You may encounter these cases when you insert a Floppy disk:
The disk is formatted and labeled. In this case you see the window as shown in Figure 2-48. You can begin using the information on your disk.
The disk is unformatted. Refer to "Reformatting a Floppy Disk" for information on formatting a disk.
The disk is formatted and may contain data. If the data is in Macintosh format or unknown to this system, you may see the a popup as shown in Figure 2-53.
