To move or copy a file or folder into another folder within File Manager when both the source and destination icons are visible, follow these steps:
Select the file or folders that you want to move or copy.
To move, press SELECT on a selected file and drag the pointer onto the destination folder. To copy, press the Control key together with SELECT on a selected file, and drag the pointer onto the destination folder.
The tip of the arrow defines the destination of the move operation.
Release SELECT.
The file or folder is moved or copied to the new folder.
