OpenWindows User's Guide
Renaming a Floppy Disk
There are times when you would like to change the name of your disk.
  1. Insert the disk to be renamed.
  2. Select Check For Floppy from the File Menu.
  3. Choose Rename Disk from the File menu.
    You see the rename disk window.
    Figure 2-54 The Floppy Rename Disk Window
    Graphic
  4. Type a new name for the disk.
    You type over the existing disk name and it disappears when you have finished typing.
  5. SELECT the Rename Disk button.
The disk is now ready to be used or ejected.
