You may need to save (or rename) a document in one of three stages:
Saving a new and untitled document
Saving an existing document
Saving and renaming an existing document (Save as)
The first time you work with a document (or file), you have to give it a name and save it to a particular location in your file system.
Choose Save from the File menu.
Depending on the application you are working in, you see a Save window similar to the one in Figure 1-27.
Choose the folder location for saving the document.
The name of the folder must be displayed under Current Folder.
Select the name of the folder from the scrolling list.
Click SELECT on the name of the folder and click Open, or, double-click on the name of the folder. If it is not displayed, double-click on "Go up one folder." You may need to repeat this a few times.
or
Type a name for the document in the text field and SELECT Save.
When the scrolling list shows the contents of the folder, type a document name and click SELECT on Save.
To save changes to the contents of an existing file:
The document is saved with the same name and in the same folder.
The following procedure saves a file under a name:
Choose Save As from the File menu.
Depending on the application you are working in, you see a Save As window similar to the one in Figure 1-27.
The name of the folder must be displayed under Current Folder. To display the folder you can:
Click SELECT on the name of the folder, or, double-click on the name of the folder. If it is not displayed, double-click on "Go up one folder." You may need to repeat this a few times.
or
Type a new name for the document in the text field and SELECT Save As.
When you rename a document without making changes to it, you will have two versions of the document, one with the old name and one with the new name. If you work with a file on a daily basis, note the name of the one you are working with so as not to overwrite the wrong one when you save your work.
