To open a document from an application:
Choose Open from the File menu.
An Open window similar to the one in Figure 1-26, is displayed.
Select the name of the folder from the scrolling list.
Click SELECT on the name of the folder, then click Open. Or, double-click on the name of the folder. If it is not displayed, double-click on "Go up one folder." You may need to repeat this a few times.
Choose the folder that contains the document you want to open.
The name of the folder must be displayed under Current Folder. To display the folder you can:
When the scrolling list shows the contents of the folder, select the desired document and click SELECT on Open.
You can also double-click on the name of the document.
You can use the same steps as opening a document for including a file from Text Editor or Attaching a file from Mail Tool. The result will be an included or attached file (or document).
