Follow these steps to rename a mail attachment in the View Message or Compose window Attachments pane:
Select the attachment that you want to rename.
You can only rename one attachment at a time.
Choose Rename from the Edit menu at the top of the Attachments pane.
The Rename Attachment popup window is displayed.
In the Rename Attachment popup window, type the new attachment name in the Name text field and click select on the Rename button, as shown in Figure 4-23.
The attachment in the Attachments pane is renamed.
The name of an attachment should never contain the slash (/) character. This can cause confusion between file and directory names.
