The Edit menu provides standard editing functions, as follows:
Undo undoes the last editing action or all editing actions, depending on which item you choose from the Undo submenu.
Copy stores a copy of the selected text on the clipboard. Only one selection at a time can be stored on the clipboard. If something is already on the clipboard and you do a Copy or Cut, the contents of the clipboard are overwritten with the new information.
Paste inserts the contents of the clipboard at the insertion point.
Cut removes the selected text and stores it on the clipboard. Only one selection can be stored on the clipboard at a time.
