Abstract: Provides a short description of the help volume.
<metainfo>
   <abstract>
   abstract text here ...
   <\abstract>
 <\metainfo>
The abstract text should not contain HelpTag markup because the abstract may be read and displayed by applications that don't recognize markup.
The <abstract> element is automatically assigned the ID string _abstract. An author-defined ID cannot be assigned. The _abstract ID can be used with the <link> element, but not with the <xref> element.
Abstract text may contain an optional <head>.
This markup briefly describes the contents of a help volume:
<abstract> Online help for the Application Manager Version 1.0. <\abstract>
When creating a link to an element within the <metainfo> element, be sure it is a type=Definition link.
The following markup shows how to create a link to the abstract:
<link hyperlink= "_abstract" type=Definition> Choose this link for an abstract.<\link>
