The following markup:
<lablist tight> <labheads> \ Unit \ Meaning \in\ inches \mm\ millimeters \cm\ centimeters <\lablist>
produces this output:
Meaning
inches
millimeters
centimeters
The following markup allows long labels to break into multiple lines.
<lablist> \Creating Your System Password:\ To log into your computer, you must enter a password. \Viewing the Message of the Day:\ To view the message of the day when you log into your computer, edit your startup configuration file. \Setting the System Time and Date:\ To set the date enter the day, month, and year in the format dd-mm- yy. To set the time, use the format hh-mm-ss. <\lablist>
It produces the following output:
Adding the nowrap parameter in the same markup produces this output:
