Assuming the necessary STREAMS modules are already loaded with the kernel, you can save the following lines in your .cshrc file (C shell example) for convenience:
setenv LANG en_US.UTF-8 if ($?USER != 0 && $?prompt != 0) then cat >! /tmp/mystreams$$ << _EOF ttcompat u8euc ldtterm eucu8 ptem _EOF /bin/strchg -f /tmp/mystream$$ /bin/rm -f /tmp/mystream$$ /bin/stty cs8 -istrip defeucw endif |
With these lines in your.cshrc file, you do not have to type all of the commands each time. Note that the second _EOF should be in the first column of the file. You can also create a file called mystreams and save it so the .cshrc references to mystreams instead of creating it whenever you start a C shell.
