Solaris Internationalization Guide For Developers
English/European Input Mode
The English/European input mode includes not only the English alphabet but also characters with diacritical marks (for example, á, è, î, õ, and ü) and special characters (such as ¡, §, ¿) from European scripts.
This input mode is the default mode for any application. The input mode is displayed at the bottom left corner of the GUI application.
Graphic
To insert characters with diacritical marks or special characters from Latin-1, Latin-2, Latin-4, Latin-5 and Latin-9, you must type a Compose sequence, as shown in the following examples:
When there is no <Compose> key available on your keyboard, you can substitute for the <Compose> key by simultaneously pressing the <Control> key and <shift-T> together.
For the input of the Euro currency symbol (Unicode value U+20AC) from the locale, you can use any one of following input sequences:
These input sequences mean that you press both keys simultaneously. If there is no <AltGraph> key available on your keyboard, you can substitute the <Alt> key for the <AltGraph> key.
The following tables are the most commonly used Compose sequences in Latin-1, Latin-2, Latin-4,Latin--5 and Latin-9 script input for Sparc.
Note -
To start these sequences, type <Compose> key and release it.
Table 4-4 lists the Common Latin-1 Compose Sequences.
Table 4-4 Common Latin-1 Compose Sequences for Sparc
Press and Release
Press and Release
Result
[Spacebar]
[Spacebar]
Non-breaking space
s
1
Superscripted 1
s
2
Superscripted 2
s
3
Superscripted 3
Inverted exclamation mark
x
o
Currency symbol ¤
p
Paragraph symbol ¶
u
mu u
apostrophe '
acute accent '´
cedilla '¸'
dieresis '¨
macron '
o
o
degree 'o'
x
x
multiplication sign 'x'
plus-minus ¿
soft hyphen -
division sign /
a
ordinal (feminine) a ã
a
o
ordinal (masculine) o õ
o
not sign ¬
middle dot '
1
2
vulgar fraction 1/2
1
4
vulgar fraction 1/4
3
4
vulgar fraction 3/4
left double angle quotation mark «
right double angle quotation mark »
inverted question mark ¿
A
A grave À
A
A acute Á
A
A ring above Å
A
A dieresis Ä
A
A circumflex
A
A tilde à
A
E
AE diphthong Æ
C
C cedilla Ç
C
o
copyright sign ©
D
Capital eth D
E
E grave È
E
E acute É
E
E dieresis Ë
E
E circumflex Ê
I
I grave Ì
I
I acute Í
I
I dieresis Ï
I
I circumflex Π
L
pound sign \xa3
N
N tilde Ñ
O
O grave Ò
O
O acute Ó
O
O slash Ø
O
O dieresis Ö
O
O circumflex Ô
O
O tilde Õ
R
O
registered mark \256
T
H
Thorn P
U
U grave Ù
U
U acute Ú
U
U dieresis Ü
U
U circumflex Û
Y
Y acute Y
Y
yen sign \xb4
a
a grave à
a
a acute á
a
a ring above å
a
a dieresis ä
a
a circumflex â
a
a tilde ã
a
a circumflex â
a
e
ae diphthong æ
c
c cedilla ç
c
cent sign \xa2
c
o
copyright sign ©
d
eth d
e
e grave è
e
e acute é
e
e dieresis ë
e
e circumflex ê
i
i grave ì
i
i acute í
i
i dieresis ï'
i
i circumflex î'
n
n tilde ñ
o
o grave ò
o
o acute ó
o
o slash ø
o
o dieresis ö
o
o circumflex ô
o
o tilde õ
s
s
German double s ß
t
h
thorn p
u
u grave ù
u
u acute ú
u
u dieresis ü
u
u circumflex û
y
y acute y
y
y dieresis ÿ
broken bar |
Note -
Compose sequences defined in Table 4-3 are not included in Table 4-4..
Table 4-5 lists the Common Latin-2 Compose Sequences.
Table 4-5 Common Latin-2 Compose Sequences
Press and Release
Press and Release
Result
a
ogonek á
u
breve ü
v
caron
double acute ¨
A
a
A ogonek a
A
u
A breve
C
C acute
C
v
C caron
D
v
D caron
D
D stroke
E
v
E caron
E
a
E ogonek
L
L acute
L
L stroke
L
L caron
N
N acute
N
v
N caron
O
O double acute
S
S acute
S
v
S caron
S
S cedilla
R
R acute
R
v
R caron
T
v
T caron
T
T cedilla
U
U ring above
U
U double acute
Z
Z acute
Z
v
Z caron
Z
Z dot above
Table 4-5 contains the Latin-2 compose sequences.
Note -
Compose sequences defined in Table 4-3 or Table 4-4 are not included in Table 4-5.
Table 4-6 lists the Common Latin-4 Compose Sequences.
Table 4-6 Common Latin-4 Compose Sequences
Press and Release
Press and Release
Result
k
k
kra
A
_
A macron
E
_
E macron
E
E dot above
G
G cedilla
I
_
I macron
I
I tilde
I
a
I ogonek
K
K cedilla
L
L cedilla
N
N cedilla
O
_
O macron
R
R cedilla
T
T stroke
U
U tilde
U
a
U ogonek
U
_
U macron
N
N
Eng
a
_
a macron
e
_
e macron
e
e dot above
g
g cedilla
i
_
i macron
i
i tilde
i
a
i ogonek
k
k cedilla
l
l cedilla
n
n cedilla
o
_
o macron
r
r cedilla
t
t stroke
u
u tilde
u
a
u ogonek
u
_
u macron
n
n
eng
Note -
Compose sequences defined in Table 4-3 or Table 4-4 or Table 4-5 are not included in Table 4-6.
Table 4-7 lists the Common Latin-5 Compose Sequences.
Table 4-7 Common Latin-5 Compose Sequences
Press and Release
Press and Release
Result
G
u
G breve
I
I dot above
g
u
g breve
i
i dotless
Any compose sequences already described do not re-appear in this table.
Table 4-8 lists the Common Latin-9 Compose Sequences.
Table 4-8 Common Latin-9 Compose Sequences
Press and Release
Press and Release
Result
o
e
Diphthong oe
O
E
Diphthong OE
Y
Y diaresis
