DPT PM3222 only: The EPROM should not be earlier than version 7A, and the SmartROM not earlier than version 3.B.
DPT PM2022 and PM2122 only: The EPROM should not be earlier than version 5E, and the SmartROM not earlier than version 2.D1.
o WD1003 Boot Address: |
Disabled (Secondary) |
o IRQ Level: |
Any legal value between 11 and 15, except 14 |
Make sure you use edge-triggered interrupts.
o IDE Boot Address: |
Disabled |
o SCSI BIOS ROM Address: |
Default |
o HBA SCSI ID: |
Default 7 |
To prevent system hangs caused by improper IDE emulation, the EISA !DPTA410.CFG file should be at least version 6E5. If it isn't, obtain a newer version from your vendor and rerun the EISA configuration utility.
Solaris installation may fail when setting up the fdisk partition table on one or more disks. On systems with a disk RAID configuration where at least one disk is new or has had its partition table zeroed out, these error messages may be displayed. If the Solaris installation fails and you see the following error messages, restart the installation. It should succeed.
ERROR: Could not create Fdisk partition table on disk ERROR: Could not label the disks |
Use the original install diskette when adding a PM3222 to your system.
